no air for 4wd or brakes
frankdontank
SC
I just bought a 1988 flu419. Runs great and hydraulics are perfect, but the air lines and tanks are rusted thru. The pump works because I can hear it hiss at the right rear when I shut it down.
I got it stuck and was wondering if there was any way to manually lock the differential without air going to the controls? All of my lines are rusted or stopped up and it looks like it is impossible to change them all with the back hoe over everything. Is it possible to just hook air to that system so I can get it out of the mud?
Frank
The FLU farm
1,446
The actual midwest, NM.
Frank, yes you can feed pressure to the axles from an external source. From one of those portable air tanks, for example.
But I'm afraid that there may be more to it than to get air to the rear locker (the 4WD you can engage manually if need be, in which case you might as well lock both axles).
I'd use the backhoe to get out of your predicament rather than trying to get things working while in the mud.
Speedwoble
303
New Holland, PA
If you tilt the backhoe, you may be able to reach the pneumatic cylinder that actuates the 4wd. It is spring loaded to 2wd, but you may be able to wire it in to 4wd. My personal opinion is , if you are stuck, the 4wd will only get you deeper. 16000lbs on 4 tires will sink. Try the backhoe.
alpine44
21
Asheville, NC - Elkton, MD
I second this suggestion having been in the same predicament but with 4WD working.
Extend the backhoe straight back as a counterweight and prop the front tires up with the loader (the loader is too weak for this when the hoe is stowed). Put gravel, small rocks or planks under the tires. Then lift the loader, release the handbrake, and use the hoe to pull yourself out backwards. The outriggers stay up for both steps.
Once you put more time on your SEE you will be amazed how easily 16000 lbs bog down and how easily the hoe moves the same 16000 lbs around when you are digging.
