No HET headlights
73m819
327
gainesville, ga.
Just as the title says NO headlights, I had then this afternoon, went to take the truck to its pickup point (so plan B, load it on the street in front of the house), NO FREAKEN headlights, non of the cbs were triped, have everything else, black out switch not on, any thoughts on this???
73m819
327
gainesville, ga.
If I knew that, I would not have been thinking very BAD thoughts about the people who designed it.
73m819
327
gainesville, ga.
no, from what I could see, the whole panel has to come up, I do not see how wires could come loose when the truck is not moving, just running in the driveway.
73m819
327
gainesville, ga.
The HET has just about NO vibration, if you did not here a bit of engine exhaust, you would not know the it was even idling.
goldneagle
1,381
Slidell, LA
I had a high beam low beam switch go out 1 time ( floor mounted style ). It drove me nuts til I figured out the switch went bad.
I had that happen on my M923 with the LED headlights. I smelt smoke from the switch. Lucky it was a sticky switch. Got it replaced and all the trouble went away.
