Nuts for MEP-002a
coastie
maine
Good morning. I need nuts for the 4 connection lugs on my MEP-002a. Does anyone know what size they are? Thank you.
Crawdaddy
Louisiana
I don't know the size off-hand, but I do know Munchies knows. I think he told me it was a something by 14 thread. From what I understand, finding just the proper nut part of the split-nut setup is nearly impossible to impossible.
Also, if you're not running 3-phase loads, you can get away with just three because L2 is only used in 3-phase applications.
rosco
27
Delta Junction, Alaska
I'll bet you 10 donuts to a Quater, those are just regular nuts, commonly used on "split ear connectors", electricians use. Take the dimensions you get with a tape, and go to the commercial electric supply house in your area and buy the same size connector, and use the nut you get there. You might check at HD or the other place, but they might not have them that big. If they do, they will be cheaper there for you.
Use Noalox on the threads, when you assemble that stuff!
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
Yes, they are a standard size nut from a "split Bolt" type of connector. Measure the best you can the outside diameter of the threads and then measure the threads on some at any electrical supplier. You'll need to buy the entire "split bolt" as they won't sell just the nuts.
Speddmon
Cambridge, Ohio
Good Luck finding them at HD. This kind of connector is venturing into commercial/industrial electrical component territory...I doubt that HD will have anything. You'll be better off going to an electrical supplier.
212sparky
Monroe/ Ohio
If you know what size it is i could look in my stock. I have around 200#s of those things. Problem is the ones under 750kcmil that i have are mostly aluminum not good brass.
coastie
maine
I contacted Thomas & Betts and they do not make a connector that large. I ordered some brass 1-14 nuts from Mcmaster. I will just fab the little clamping tabs.
Speddmon
Cambridge, Ohio
Find a distributor for Ilsco brand split bolts. They should have the size you need, I think they were the OEM of the ones the military used on our sets, but they would have been a special product run due to the special design of the bolt. But they should have something with the proper thread size you need.
