One stuck glow plug
spoort1
rising sun, md.
Well, my m1008 wasnt firing up after multiple attempts. I didnt want to burn up the starter so I ordered new glow plugs and pulled the old ones. The old plugs came out pretty easy (lucky) except one which was swollen too far. All but two were swollen. 13g's were in it and I ordered wellman 070's for it. No modifications on it except the toggle switch under the dash which was in it when I got it a couple weeks ago. I'm hoping that the old 13g's were just that, OLD, and not a problem with the system frying them up. I still gotta get that last one out. Wish me luck.
spoort1
rising sun, md.
yeah, Hopefully it will come out with some elbow grease and vice grips. I will try tomorrow and see. I may have to get a glow-plug puller. Yikes...
raiburn
Fort Wayne, Indiana
I could only get 3 of mine out, the rest were swollen.
I bought the tool, and they all came out, but it was still a battle.
In your case Spoort, if you install the other 7 first, start the truck and drive it around until its nice and warm. This will help the swollen one bend and reform as you pull it through the hole, and stop it from breaking off inside the pre-combustion chamber.
I couldn't get vice grips, or a pry bar to work on any of mine.
JAD561
BETHPAGE NY
I used the delco ac13g plugs. They lasted 4 weeks. 4 swelled up and would not come out. I ordered the removal tool, and had the stuck ones out in less than 1 hour. the tool was worth every bit of the $ 75 that it cost. I believe that the company was called either jt&t or jt&a racing.
1,193
Warning, If you start it with one or more GPs that are bad(or good but not connected), you may burn out the rest of them, nearly instantly.(unless you resupply them with 12V, as described in previous posts).
1,193
spoort1
rising sun, md.
I found it with a search.30mm. Thanks for the advice doghead. I will see if I can find a magnet that I can get to it with. Wish me luck everyone.
Lawrence of Arabia
Howell MI
I bought an OTC puller and it worked great, but I have one that would not come out. I just replaced the seven and one day I will have to pull a head or do it when I rebuild the engine.
1,193
I think others have also mentioned a shop vac, has sucked them out through the injector hole. GL
spoort1
rising sun, md.
Well thanks for your help everyone. I was able to get the plug out with a shop vac. I tried a magnet but it wouldn't grab well enough. I could feel the plug in there with my pinkie finger and was able to find a hose small enough to get in the injector hole. Thank God for experience (doghead), shopvacs, hoses, and duct tape. SHE IS UP AND RUNNING.
spoort1
rising sun, md.
Oh, one last thing now. got her running and new 1000ca batteries and she is not keeping a charge. I'm checking the alternators tomorrow and see which or if both are bad. :( headlights are bright and voltmeter runs in the green when she is running but the new batteries are near dead when I try to start her without a jump. Scratchin my head here.
