Pic's of leaking return fuel line
crusty
New Castle, DE
RE: Pic
Each injector should have a hard line from the injector pump and two rubber hoses. The rearmost injector on each bank will have one hose and a rubber cap. From the picture it appears as if you have one or more of the rubber return lines missing.
rfischba1
Fort Meade MD
RE: Pic
After a closer look, I beleive the top open hole on the injector is missing the cap, that where the fuel is comming out. Is the cap part of the (return line kit from NAPA?) Any info on these caps? TM??
Thanks.
Crash_AF
Colorado Springs, CO
RE: Pic
That one is supposed to have a line connecting it to the injector behind it. Only the rear (closest to the firewall) injector has a cap.
Later,
Joe
rfischba1
Fort Meade MD
RE: Pic
Looking the the 1st pic it looks like a top and bottom port hole showing, the bottom has a hose conected, that goes to the pump? correct? What covers the top port hole?
does that get another hose or cap? does it stay uncovered?
My truck is still at GL so I only have my pics to go by.
