Pinion Bearings - Napa?
SixSpeed
Banned
1,107
Tampa, Florida
Hey Guys, I know you can get the seals from Napa, what about the bearings themselves? Not too much info on the bearings around, mainly the seals! Thanks!
m16ty
218
Dickson,TN
Have you pulled the bearing out yet? I've never seen a deuce pinion bearing but I've yet to see a bearing that didn't have a number stamped into it. If you can get the number off the bearing NAPA should be able to cross it for you.
1,142
Has anyone ever posted the Timken or Napa numbers for deuce pinion bearings? I searched and checked the old crossover chart and saw nothing.
C
jasonjc
291
Gravette Ar.
There are 2 different bearings I'm getting these #'s out of TM 9-2320-361-24P datedAug 2006.
Fig 74 item 12 3110-00-100-3566 P/N 29585
Fig 74 item 15 3110-00-227-3711 P/N 22780
The seals show to be the same different item # but same NSN and P/N 5330-00-143-8666 12470104
hope this helps
jasonjc
291
Gravette Ar.
I tried both of those P/N on O'reily web sit. The 29585 can up as a hose,muffler or thomastat. 22780 did come as a brearing thought,but right or not I do not know.
Shep on here needs brearing and he works at O'reilys so maybe he can get them in and see if they are right or not???
Chief_919
103
Western NC
Fig 75 item 12 3110-00-100-3566 P/N 29585
Fig 75 item 15 3110-00-227-3711 P/N 22780
hope this helps
Item 12-
0066128- New Holland
29585- Federal Mogul, Kaitlin Corp, Tyson Div SKF industries, Timken, Meritor, RBC Bearings
29746X- Massey Fergesun
312751- Volvo, Euclid
532329- Yale
60331R91, ST2012- International/Navistar
62AX344- Mack
Item 13-
22780- Timken, Kaitlin
2671D5- Diamond Reo
911585- Sasco
I have more numbers for each, but them we are getting into the more obscure makers. These should be enough for any competent supplier to cross for you.
I am keeping track of all these, one day I will publish a small cross reference guide for the M35 series trucks you can carry in the glove box.
