Pintle R & R
BKinzey
Hollywood, CA
I'm trying to remove the pintle from the mounting plate. Took the plate off the bumper, got the castle nut off & washer and that's it. I thought it would come apart. Couple of whacks with the hammer got no results. I've pulled the 4 bolts out and the bushing/support plates on both sides of the mounting plate will move with some effort. I'm wondering if these are threaded as well?
Soaked it in penetrate and applied heat to it yesterday. Soaked it again for overnight. Before I get out the BFH I'm wondering if I'm missing something or it's just dirt & rust holding it together?
Thanks.
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
Four foot pipe to turn it(in the hitch)? I don't know about the cucv, but the 715/725 sometimes need to be twisted out.
BKinzey
Hollywood, CA
Hmmmm. Ok.
I'll see if I can anchor the plate to something and use a crow bar to turn. If anybody has other methods please post up!
Thanks!
acetomatoco
that bare bear must have been funny with no fur... It is easier to remove pintle and shaft from mount before loosening bolts on rear frame cross member...take off castle nut and washers.. tie truck to big tree and off you go....
acetomatoco
And of the serious side.. use the shop press to push it off...or a hydraulic jack against a coupla big wooden blocks and the concrete wall in your garage..or your little 10 ton porta power...
1,823
I had one on a 1952 M275 that was plenty stuck. Chain and tree did nothing to help it along, not even with some jerking action. Copious amounts of heat with the hot wrench proved effective. On the other end, the 1953 M108 was stuck as well. A spud bar and some jumping on the end after a feew shots of grease got that one spinning. Little note on deuce pintles. Older ones had several zerks to prevent this, the newer ones don't.
BKinzey
Hollywood, CA
I've got a 6 ton jack and a about 8" steel post. I'll chain the pintle plate to the post and put the jack between the post and pintle. We'll see what gives first :lol: :lol:
Probably me :oops:
BKinzey
Hollywood, CA
Jack didn't seem to help much. More heat, more PB Blaster.
Then I got the UH - DUH idea. I pulled the Zerk fitting and sprayed into the hole. Over the next couple of hours I gave it a couple of good shots and then the 2 pound sledge. It finally came round to my way of thinking and came apart.
Cleaned up pretty good after that :D
