Pioneer Set
willysmd
KENT. UK
OK another question
Where should the pioneer set go on a jimmy, bearing in mind I have a workshop body on the back, any suggestions please.
FrankUSMC
30
Newport, NC
Mark
I have seen them mounted in several places. On the two that I had, the rack was mounted on the drivers side, on the hood panel. Look there to see if there is any holes were it was mounted. It will cover the vents in the panel, but the rack will not stop the flow of air.
One of the few, Frank USMC RET.
Scrambler
the Netherlands
Some have the axe on one side under the cab and the shovel at the other side. I mean the (almost)vertical part of the step. I should have some pix of that...
willysmd
KENT. UK
Thanks be great if you have
