Plastigauge
ldmack3
1,740
N. Central Idaho
Can't find any spec for the rod or main bearings for the plastigauge. Only engines I've done before were small block and the books gave the spec.
Checked 9-2815-210-34-2-2 and found the torque but not the plastiguage reading.
GopherHill
1,264
Thomaston, TX
It varies by the size of the journal as I remember. Find an older Motors Manual. It has information on plastigauge use and bearing clearances, maybe on the engine you are working on.
ldmack3
1,740
N. Central Idaho
I know how to it, just what is the required tolerance.
Valve lash and timing are all that is on the engine data plate.
Edit: General is .001 per inch of journal size, but I was looking for a spec for this engine.
