Jeepsinker
- 467
- 83
- Dry Creek, Louisiana
So I received the battery adapter from Brooke at PRC68.com yesterday, picked up some good fresh Duracells today and powered up my 77 off of the vehicle mount for the first time today. I am getting zero audio out of either of my H250 handsets ( one of which is brand new) or either of my external speakers. I do get audio (static) out of the speaker on the AM2060 base when I power it up that way, but still get no audio out of an external speaker if I hook one up while the radio is on the base. Looking at the guts of the radio, it would appear as if the obvious culprit might be the A55 receiver audio module. Any other common causes of this? I can't find any broken wires or loose solder joints, and I did clean the handset and transceiver side contacts with an eraser. I also disassembled the cable ends on both handsets and checked for broken wires there and found none. It would be great if I could just drop in a replacement A55 module and be good to go, but things are never that easy.
