Progress?
Adamlee
Alexandria, VA
XM757
That 8-by is looking good!
Keep up the good work, Bjorn!
I'm looking forward to when this becomes your optional daily driver! :driver:
Adam Lee
cranetruck
92
Meadows of Dan, Virginia
RE: XM757
Thanks ACE, I'm all set now. The NSN is 2540-00-113-4180 (Model 10530A24).
I have had 4 ea units to work with, two of the correct model. Got one humming and ready to install, but would be nice to have spare parts for the others.
Need one ignitor wick, guess that means the vaporizer burner needs to be replaced and rebuild kits for the metering valves would be nice too with O-rings and gaskets.
The control box came from Austin Weber and is the correct one. It normally mounts on the top of the windshield, but I made a bracket for mounting as shown in the image above, more convenient when the windshield comes off.
If rebuild kits are available, let me know.
JDToumanian
14
Phelan, CA
Wow, that's a remarkable difference visually... Not to mention all the mechanical systems you have gone through!
What's the situation with the cranetruck, and it's rod-knocking motor? Have you dropped the pan yet? I may have missed a thread on it while I was recovering from MV burnout...
Jon
