PTO Bearings
fpchief
229
South Alabama
I took my PTO to have it given a thumbs up by the local heavy duty drivetrain place since I had it off. The transmission had bad leaks at the boots/seals and sat for many years like that so inside the pto got really rusty. It still turned what seemed to me just fine but the drivetrain place said it needs new bearings since they are rusty. I need some advice on this and also can these bearings be sourced from anywhere?
Karl kostman
922
Fargo ND
Sorry I dont know if the bearings can be sourced but I am sure they can just need to number, virtually every bearing mfg indexes off the Timkin #. If you have any rust on the rollers or ball depending on what type bearing you have then your going to have pitting you already have it apart good idea to do the bearings, I always error on the side of caution for better or worse!
Karl
rustystud
3,392
Woodinville, Washington
Karl
Totally agree !
In my opinion, new bearings are cheap insurance. I found all of them "new" on eBay just last month for 1/4 the cost of new. I'm rebuilding another PTO I had sitting around or years now, just never had the time to get to it until recently.
1,193
Easily found using the nsn# from the parts TM.
frank8003
4,990
Ft. Lauderdale, Florida
State which TM's are applicable to this PTO.
Like the big box with the 5 shafts and 9 bearings in it.
Is it like TM 9-2320-361-34P figure 239?
fpchief
229
South Alabama
That be some good dang info!!! Going to try to make it to a computer this evening. No computer access for several days. Kinda hard to go through a TM on a phone. Thanks Sir.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
I just inserted all the bearing numbers in this exploded view diagram (taken from my favorite parts book ORD 9 SNL G-742, JAN1955...)
Fig. 20-12, transmission PTO, bearing numbers.jpgFig. 20 -12, PTO, legend.jpg
Except for the input gear roller bearing assemblies (found only through eBay), all others are std/popular sizes.
fpchief
229
South Alabama
View attachment 779005View attachment 779006
View attachment 779008View attachment 779009
Well, I found all of them on Amazon, (including the 94320) with exception of the M-2016. Have not been able to locate most anywhere. Maybe a call to Timken next week?
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
You will need one of each, referring to the needle bearings. (One B & one M)
All three ball bearings should be open (-> not sealed, not shielded)
