Push Button light Switch, fire hazard??
emmado22
166
Mid Hudson Valley NY
the "extra wire thing" is a load of crap. They are all the same, they all burn/catch fire/melt. Not worth it. I talked to the manufacturer one day, there is no "1st version/2nd version. I had one until it almost melted my wiring harness..
Smokinyoda
Franklin, NC
Thanks for clearing that up. Looks like I was lied to.
Gunzy
67
Roy, Utah
The push button switch may be OK if ALL of your lighting has been converted to LED. Even if they are I would still use the 3 lever type switch.
dmetalmiki
2,033
London England
WOW! Talk about taking a simple switching device and turning it into one complicated, malfunction prone piece of crap.
Great comment, and (so) heart felt! Frankly there is much about modern Fighting vehicles that leaves so much to be desired.
I for one UNDO the "new style " handbrake levers on the deuces. Especially thought out and carefully designed to be (accidentally?) pushed off every time you exit the flipping truck!. There are other pointers..but I reckon most folks know (and just) put up with them. (rant over).
papakb
1,196
San Jose, Ca
The push button light switch looks pretty cool but after having one in the HMMWV for the last 4 years I can tell you I'd never install another one. I've had no electrical problems of fires but to operate the d**n thing you have to look at it to make sure your hitting the right switch so if your motivating down the road it's a bummer. The old 3 level switch operates just fine and can be done by feel.
Kurt
KG6KMJ
papakb
1,196
San Jose, Ca
light switch
The extra ground wire on the push button switch was for the HMMWV who's body is such a piss poor return path to ground. It needed to have the switch electrically bonded to the ground system so that added a wire that physically attached it directly to that system..I have a push button switch in my HMMWV and hate the darned thing. You have to look at it to make sure your pushing the right button and even then you have to push them twice. Give me the old brail system three lever switch that you can operate with your eyes closed.Remember the KISS principle, it works!
Kurt
KG6KMJ
