Question about wheels types....
exhogflyer
131
Albany NY
Ok, first let me say I HAVE searched but I'm not really sure what I'm looking for. My question is : is there SOMEWHERE an article or list that explains the different wheel types? In other words, I'm reading how a HEMTT wheel might fit on a deuce but with some kind of adapter, but some other type of wheel just bolts on without problems but trouble is I HAVE NO IDEA what these wheel types are. Add to the mix that some 5 ton wheels might fit but you need "this" if it's a "that". Thanks!
porkysplace
1,494
mid- michigan
Any thing other than stock lock ring wheels and M35A3 wheels (super singles) will require adapter plates .
greg burns
Glade Park, CO
exhogflyer:
Another option is to buy aftermarket wheels from somewhere like Boyce Equipment Co in Utah. They have two different wheel designs that fit the Deuce. They are pricey but you don't have to buy any adapter plates or the hardware to mount the adapter plates. Long's Wheel in Florida also used to sell custom wheels for Deuces.
porkysplace
1,494
mid- michigan
exhogflyer:
Red Barn Customs has aftermarket deuce wheels also but they are approved for highway use by the D.O.T.
That is the thing you need to verify in aftermarket wheels.
Fatalid
11
Mesa, AZ
The most common seems to be MRAP wheels on adapter plates. Several companies and individuals manufacture adapter plates that go from the 6 lug 2.5 ton Rockwell hub to the 10 bolt MRAP wheel.
In reality, if you have the ability (or know someone who does) to CNC adapter plates, then you're only limited by the fact that the inside clearance of the wheel has to leave enough room for the 6 original lugs.
Otherwise, stick with A3 rims (direct bolt-on), or MRAP wheels and adapters (most common, and thus most available)
Fatalid
11
Mesa, AZ
I took some pics -
If you aren't getting bolt-on wheels, and are thinking of having adapters made, the inside opening needs to be approx 11" to allow for the original lug nuts to mount to the adapter plates. Just FYI
So if you're thinking of being "creative" with your wheel choice, your only limiting factors are the center opening, and the actual wheel size (can't really go smaller than stock, or they will hit brake assemblies)
exhogflyer
131
Albany NY
I'm trying to learn the wheel types so I can make an intelligent decision :)lol:) when I finally pop for super singles. Guys, I DO appreciate the good info!
montaillou
845
W.WA
As you can tell from the replies, there are a lot of options.
You might want to think about what kind of look or what you want to use the truck for, list your budget and ask specific questions. Also, some of these options might need to be done by yourself as they may entail liability issues (for instance, I doubt many (any?) tire shops would even touch an adapter plate) and this might also affect what you want.
I'd suggest an image web search to see what people have done, get some ideas, then ask more specific questions. For instance, even among super singles, there are several different options.
Tire-wise, the stock NDT's to 46" (if you're sticking with 3 axles) and stuff in between. If you are going to bob your deuce, you could go even larger.
Wheel-wise, whatever works. These aren't Ferrari's, where even a little offset can be problematic, there's quite a bit of leeway in what you can do.
11Echo
96
CT W. R.
Not true.
MLVW wheels perfect fit and DOT stamped.
The MLVW wheels are 5 degree flange. They are 6,000 lb rated unlike the A3 wheel which are rated at 4,000 lbs.
They like most tires.
MudMarine
15
Jacksonville NC
I took some pics -
View attachment 760546View attachment 760547
Man if you were closer I'd buy these from you
Fatalid
11
Mesa, AZ
Not true.
Yup... Forgot about Canada :)
Cgray
22
Lake Geneva, WI
MRAP wheels?
These have an 13" spread instead of a 11" that the FMTVs have. Someone mentioned they may be from the newer Caimen or the RG31 variant. They are steel and their weight is over 100# each
