Question for cold weather starting
Carlo
21
palazzago italia
To use the ether You press and hold the button down for three seconds and then release it count to three and turn over the engine and it fires right up.. It was 35 F this morning and I didn't have to use the ether at all and it fired up with no problem................. [/QUOTE]
You WILL damage the engine this way. The instructions on the dash CLEARLY state to release the ether while the engine is turning over. Doing it your way will overload a single cylinder that has an open intake valve![/QUOTE]
Your right. Good call.
