Questions and Help on WC 22 T215
Jeeagle
Chattanooga, TN
Restoring a WC 22 T215 at my new job. Have few questions if anyone may know.
The Original Bell housing (or at least one removed from truck) has one hole for the Transmission Bolts missing. Never machined out or thread just flat area. Looking to the front it is the bottom left side. Of the Four Transmissions we have (Two Civilian and Two Military castings) none of them have a different bolt pattern. Is this an issue?
I need to rebuild or find a replacement PTO for the truck. After weeks of soaking in PB blaster and heat I was able to split the thing apart to find the gears highly pitted.
Also looking for any information on how the PTO lever was held in place. This truck and the others were completely disassembled with much documentation so I am putting a puzzle back together without really good reference. I've googled my eyeballs out but the photos I need are the ones that don't seem to exsist.
Here are few photos!
What I started with
PTO taken off truck. Packed with "Rust Dust"
Current Status (had to remove bellhousing to repaint correct color)
Jeeagle
Chattanooga, TN
Figured out the Bell housing Transmission deal. Still looking for PTO info. Although I am assuming with no reply, either no one cares or no one knows.
gerrykan
SGF, MO
Register over at G503.com, and post your questions in the 1/2 to 2 Ton forum(link below), lots of WWII Dodge experts there.
I'm at work, and can't view your photos, but I might not be too concerned with the pitted PTO gears, if you can't find a better PTO.
Winch PTOs on restored trucks usually do not spend much time running under a load.
http://g503.com/forums/viewforum.php?f=25
