Radio Tray help
juanprado
3,116
Metairie/La (N'awlins)
Look on post 19 of my thread
nairb
115
33
Liberty Hill, TX
Thanks! I've been searching threads for a clear pic like that but missed this one.
juanprado
3,116
I am not sure. What I found is there a ton of different tm's for install on hmmwv based on the radio (s) used or other gizmos they held and intercom thrown in the mix.
R442, flavors of sincgars including double stack, and newer harris models. Also the different styles of navigation equipment. That is why I suspect the trays have tons of holes depending on use.
There are at least 2 different bottom trays, one real wide bottom, then the add on middle shelf without a bottom tray and a few different tops.
Lots of tray salad possible.
NDT
7,236
Camp Wood/LC, TX
Seems like if this were a field mod, you would see evidence of the tray legs being cut off with a saw and hand drilled holes for the feet.
juanprado
3,116
I had not seen that. The top trays already have different sets of holes for height on the mounting tabs.
I wandered what models or set ups needed the different spacing for the bottom feet as the tubs I believe are predrilled from amg.
Then to add more to the mix you have the turbo dog houses and the blue force tracker mounts.
TOBASH
3,887
Brooklyn, NY
IMHO, just get 1/8” soft aluminum sheet and make the feet. Simple cheap and effective. No one will notice or care.
DREDnot
497
Phoenix, AZ
First problem is that your upper stud brackets are upside down. The stud should be in the center of the air duct.
Then put the small green symmetrical feet in the middle and the black feet on the bottom.
Once you fix that upper stud problem the rest will line up right and be level .
Retiredwarhorses
4,528
Brentwood, Calif
The stud brackets are in the correct position for an A2 truck.
