Radio
Warthog
244
OKC, OK
I don't know if "anyone" will fit. Kipman yes but others no.......:)
The hole for the radio is a standard 1980's size. Most aftermarket ubits will fix.
There are dozens of threads covering the install of a radio.
The stock ignition lock does not have an accessory position. If you change out the lock you can make the ACC work, but you have to tap off the Wiper fuse. There is a write up on this also.
http://www.steelsoldiers.com/cucv/82247-my-new-ignition-switch-has-accessory-stop-but.html
