Polverone
- 4
- 38
I just got my duece registered (finally!!)
and now it is time to drive the snot out of it. I thought it was a '71 but the gal at the counter put a call in and said it was a '73. So yay!
Now, only one problem, I just noticed that the inside of my left front duals is leaking gear oil. It happened on my last drive (those trip permits were getting pricey every week!), and it is spraying the underside of the bed. Dang!!
Not real bad but "it just ain't kosher" that way.
I did a search on the subject and came up with the following advice.
http://www.steelsoldiers.com/index....e=viewtopic&t=173&highlight=deuce+tips+tricks
I checked out Saturn Surplus and they show an axle seal and also a gasket.
Is this correct? One of each needed?
If anyone has any more input or parts I need please let me know.
Oh by the way, I have read about cleaning the "vents" on these axles to make sure that the seals don't blow from pressure. I know it wasn't a long enough drive to get really warm but what do I know.
Where is the vent(s) and how do you clean them?
Thanks for any advice
