Remove Front Bucket Loader
73m819
328
gainesville, ga.
It is not hard, use a 55 gal. drum, place a 2x6 or 8 across it, set the cross bar on the drum with bucket on ground, remove bolts, use bucket to lift frame out of brackets, put a piece of wood in each bracket, set frame down on wood, disconnect hoses, MARK THE PAIRS, back up slow while making sure things clear, DONE OR use your wrecker and just lift it off, OH you do NOT have access to a wrecker, then now is the time to get one.
73m819
328
gainesville, ga.
Very easy, can be done by one person but TWO make it REAL easy, using a WRECKER makes this a ONE person, 10 min. operation then :beer:.
