Search function very picky
cranetruck
92
Meadows of Dan, Virginia
Looking for an old post, I typed in the number of an instruction sheet, that I knew was in the post, PM-32333. The on-site search function came up with zero hits. When I did the same on Google, I got my post in one of the results....
mangus580
282
Western NY
Bjorn, your post didnt have the - in it. I performed the same search using PM 32333 and came up with your post at the very top.
1,142
I search for stuff online (and at work within our system for a living and I have a suggestion.
The more characters you add, the more chances there are the search won't find what you need.
For example, you knew you needed PM-32333. But, what if you had accidentally typed "LM" instead of PM in your original post. You wouldn't find it by searching for PM-32333.
To avoid this, search for as few characters as you reasonably can that will still isolate the item you are searching for. In this instance, I would have searched for 32333. The odds of anything other than what you are searching for coming up are slim. Maybe a member's zip code or something, but not enough to significantly increase the search results.
