Shifting issues
haleybeast
Columbus, OH
My son's '85 (mileag unknown) was having trouble shifting out of second gear. I read several blogs and the TM. This weekend I replaced all the vacuum lines, the modulator, and the vacuum regulator. No affect. Need some advice on nexts steps. Thanks
br44
California
Hey I know this sounds odd, but change your fuel filter. I used to have the same problem getting out of 2nd and it ended up being the engine struggling to do anything, much less shift.
cliffyp
Brownsville, Texas
"Trouble shifting out", as in late shift, hard/harsh shift, doesn't shift? Does 1-2 feel normal? Open your governor door and pull out the governor to check it out. Also put a pressure gauge on the trans and see if it's making the correct pressure.
haleybeast
Columbus, OH
Thanks for the input. Odd thing is there is pressure up top at the regulator, but nothing getting to the modulator. I'm going to guage all the pressure, try those few things and check for leaks/breaks in the metal line.
engineman2
Enon, Virginia
The vacuum regulator on the injection pump might have gone out or be poorly adjusted. I don't remember all the details about it but I'm sure someone more knowledgeable than me will chime in.
1,187
There are lots of good ideas posted here, but why not follow the troubleshooting procedure in the TM? It's organized and complete.
If that fails to find and correct your issue, then start guessing...
Tow4
669
Orlando, FL
I had the same problem with my M1028A2. If the vacuum pump is working; by pass the vacuum regulator at the injection pump. If it shifts, it's the regulator. Note that it may shift first to third very quickly, but you will know the transmission is shifting.
Good luck.
haleybeast
Columbus, OH
Turned out to be a split in the metal pipe from the regulator to the modulator. I did a temporary bypass with vacuum tubing and shifts like a dream. Any ideas where I can get the metal piece or just easy to bend one myself?
engineman2
Enon, Virginia
I don't know where you can get factory replacements. But I imagine that sections of steel brake line would work well if you just cut off the flared ends. The brake line is cheap and easy to bend so I'd suggest that. Or you could opt to stick with the rubber line and just secure it out of the way. Glad you figured it out! :-D
1,187
So you did use the TM, must have figured it out with step#2.
51. WILL NOT SHIFT PROPERLY
Step 1. Check transmission fluid indicator for proper reading. (See TM 9-2320-289-10)
Step 2. Inspect vacuum hoses, vacuum pump, and vacuum regulator valve for improper
connection, leakage, or damage.
