In preparing for next weekends rally at Haspin, I was putting in a new temp gauge like camogriz did in his truck. I was placing the sensor in the water pump location since that's the only place this sending unit would fit and I could keep the light as well. Anyways, I took the belt off the passenger side alt and loosened up the lower bolt and rotated it out of the way. When I went to slide it back over to put the belt on the hot terminal burned through the boot and arc'd to the bracket for 15 seconds probably. I had smoke coming from there and then wires up on the firewall. The alt was stuck and hard for me to rotate quickly back by hand.
I have attached pics of where the two visible wires are burnt. The truck did still start, but I haven't checked anything else. I unhooked the batteries (yes I know I should have in the first place, believe me I've already beat myself up about it). So far I've traced to just the two wires circled in red that melted through. I did hear popping and saw quite a bit of smoke while this was going on. What is the best way for me to trace through this and find out what all could be damaged? I'm going through the TM's and FAQ links now. I just wanted to get this post out there to generate some thoughts so hopefully I can get through it today.
These two spots are melted wires (both blue)
This is the wire that comes across the firewall and connects to the melted wire
Boot where is burnt through
What started out as an enjoyable project
I appreciate any input and advice. Thanks-Jason
