Simple question..
fpchief
225
South Alabama
Will most of the sound powered phones talk to each other?? Will a TA/312 talk to a TA/1? Just need the phone, batteries, and slash wire for a 2 phone system right? J box for multi phone?
Sent from my SM-G955U using Tapatalk
Scrounger
69
Southern, Maryland
The TA/312 uses a couple of size D batteries, so it has a practical range of over ten miles. The TA/1 uses sound power to work and will work up to about three miles, even if the book says more.
The TA/312 will ring the TA/1 and visa versa. To get the best use, having good wire, that is dry makes a world of difference.
For a party line, one where every phone rings at the same time a SB993 switchboard works well. However, if you use TA/1s the system will be limited because of the limited capacity of the phone.
fpchief
225
South Alabama
Can I do a party line without the use of a switchboard? Just have about 4 phone with continuity between each?
Scrounger
69
Southern, Maryland
You don’t need a switch board unless you plan on running a lot of wire. If you use four TA/312s I would limit the total wire length to ten miles. If using TA/1s limit the total wire length to three miles.
There are many ways to run the wire.
Home runs, all the wire starts at the main house, one to the front gate, one to barn one, one to barn two. The three wires connected to the terminal posts on phone at house.
Wire goes from front gate to barn two to barn one then to main house.
The problem with running long lengths is the resistance reduces the signal and it makes it harder to hear someone on the other end.
