Soft Doors vs X doors - what do you prefer?
Waschbrett1981
Germany
Hi guys,
Quick question for you.
what would you prefer for a 4 door soft top humvee?
Soft doors or X doors?
Currently I have soft Doors and I am not really happy with those. Everywhere water is coming in and the noise is quite loud.
would be a change to x doors an improvement in terms a leakages and noise?
maybe there are better nOEM doors available, can you recommend?
thanks
marcus
badgerd
Electronic Jedi
102
65
Chesapeake VA
X doors leak and rattle more than soft doors. If you take the time to fit them properly and work on seals and rattle reduction, they’re a little better.
My soft doors sealed well and were quiet, I moved to X doors because I added a helmet top and they fit better.
If you’re expecting a night and day difference, you’ll be disappointed.
Sent from my iPad using Tapatalk
Coug
4,589
Olympia/WA
The soft doors you can bend and tweak the door wire in order to make it a tight seal. I live in the Pacific NorthWest and don't have issues with water coming in through the door after a little bit of bending.
X-doors you can adjust the hinges and the latch post a little, but other than that if they don't seal (with a good seal strip around the frame) you're kind of screwed. They're also a lot more noise from rattles and whatnot.
Milcommoguy
2,363
Rosamond, CA
Water, dust, noise, visibility, rattles, weak locking mechanism, possible theft (can be remedied), shipping $$$, and costing more everyday. Your choice.
It's the HumV experience, CAMO
MarkM
CODE BROWN...It's all going to sh~t !
2,066
WOBURN. MA.
I much much prefer the X-Doors over the soft doors. Security and esthetics are the main benefits of the X-Doors. Shrapnel resistance over the soft doors is a very minor consideration but what the hell. The X-Doors are much quieter than the soft doors for road noise. Prices for X-Doors is getting ridiculous but they do increase the value of the HMMWV substantially.
Mark
20,501
Mark
So, silly question here: If there is a canvas top - would you ever lock the doors?
If the doors are locked, what does a replacement canvas cost when the crackhead cuts your top open?
20,501
It's a deterrent and with Blink cams it's all I can do.
Mark
Cameras are a definite plus! Especially if they happen to have some sort of motion detection embedded. A friend has a civilian Jeep and he has a metal box bolted through the body down to the frame. He uses that for higher security things. After two tops were cut, he has worked hard to NOT lock the doors.
Dang shame that it has to be that way...
MarkM
2,066
WOBURN. MA.
If someone walks up to the truck at night the camera sensors it and alerts my phone and when that happens a 200w 20K lumens flood light comes on. I wake up to any alerts like that and look at the phone and if need be I can shoot down the stairs to welcome my uninvited guest and welcome him. As I said I do what I can.
Mark
JetbikeAnt
125
Elverson, PA
The biggest thing I miss on the M988 I sold is the soft doors. Driving that Truck with all doors off in 2 minutes is something I truly miss. Somedays when it was cool in the morning, but warm in the afternoon, when I got out of work I just took them off and put them across the tunnel and back seats to drive home. The up armored X-doors on my M1045A2 are way cool, but I bet their not fun taking off. This is the one advantage the M998 had over my M1045A2. Now being shot at is a different scenario. LOL!!!!
dhaumann69166
78
Hyannis, Nebraska
My first Humvee was hard too and hard doors and my second is soft top and soft doors. I don’t notice much of a difference as far as road noise but the soft doors seal way better and don’t rattle. The soft top and doors also seems to hold heat in better in the winter time. The hard top/doors sucked the heat out faster than the fan could push it out. The biggest issue I have with my soft doors is the stitching is starting to come apart on the zippers. I have had stitched it with fishing line but it’s a pain in the ass. Luckily I found someone with a machine to redo the sewing. The plastic windows in the soft doors feel like green house material in the summer making the inside like an oven. After tinting the windows though the heat issue was eliminated.
My biggest concern with the soft doors was branches and brush. I do pasture clearing and tree removal and when we roll into places trails are all overgrown. I have been through cedars, buck brush, thorns and plum thickets and have ZERO rips in the doors or top. All in all I like the soft doors better I will say I like the look of X doors better.
