74M35A2
- 342
- 83
- Livonia, MI
Thought I would post a photo of what happens if you hold your starter on longer than the specified 30 seconds. Brushes and armature/commutator run the hottest. Starter is a very powerful motor (6kW or so), with zero cooling. In the picture below this armature got so hot the varnish melted off the copper wiring, and that caused it to short out, draw more current, and then melted the armature wiring until it disconnected and stopped working. One low hour armature for reference. Don't use your starter to prime your fuel system. If your truck does not start in 30 seconds, stop, and figure out why.
