starting issues
tjhaga
Colfax, Iowa
My son has a 1985 K5 Blazer. It sat for a month he started it and it started right up. He let it run approx 45 minutes. Tried to restart it after shutting it off, only gets a rapid clicking sound. He put new batteries in it approx 10 months ago, the terminals are clean. Neither of us are very mechanical. Sounds like bad alternator?
Westech
CPL
6,104
211
cow farts, Wisconsin
might be bad alternator(s).
make sure the generator lights turn on when ignition is on (power on but engine not running)
you may have to give the engine a little rev to turn on the alternators. So if engine was started and not reved up a little
the batteries may have been drained.
charge the batteries and start engine, rev it up just a tad (1000 rpm) and check voltage at batteries.
13.5-14.5 on first and 26-29 volts on the second.
a cucv might not be the best choice if you are not a tech type. they need and loved to be tinkered with
1,193
Better to ask and learn, than never ask or learn the hard way.
tjhaga
Colfax, Iowa
Thanks for the suggestions. He let it idle for about 45 minutes, may not have rev'ed the engine enough. Will check voltage with engine running May be a day or two before I can help him check things out.
Tow4
672
Orlando, FL
Anything over 13.7 volts at each battery is OK if they are fully charged, but your volt meter may read low. Check the batteries with a VOM.
1,193
Here's a clip from the alt repair portion of the TM.
Voltage regulator setting
should be a minimum of 13,5 volts
and a maximum of 15,5 volts,
