Steering box M809 series
txturbo
74
Rosenberg,TX
Every steering box I’ve ever tried adjusting was a failure. You can adjust the free play out when it’s centered but then as you turn it off center in either direction it gets tighter and tighter. If you keep trying to turn it more you can break the case or a gear. The only real solution is to have it rebuilt or swap it out with a good one. There are rebuilding companies you can send it too.
