Super High Oil Pressure - Reads 120 after 5 seconds!
collinsprinkles
Yakima, WA
Today when I started my M185A3 I checked the air pressure and saw that it was already at 120, I thought "dang, I didn't drain the tanks after driving yesterday" then I realized it was the oil pressure gauge!!! I shut it down immediately. What could be going on? Whenever I start it up it hits 120 psi in about 5 seconds. Is something seriously wrong or is it just a problem with the gage?
Warthog
241
OKC, OK
You need to make sure the sending unit and the gauge match. The is a 60psi version and a 120psi version.
1,190
What is the temperature there?
collinsprinkles
Yakima, WA
It's in the thirties. I freaked and called my dad. He said that once it would warm it the pressure would drop and it shouldn't hurt anything. I let it warm up as much as possible with a piece of cardboard over the radiator (I have the winterfront cover but still haven't had time to figure out how to install it), I took it for a little drive and once the engine got to around 160 the pressure dropped. I picked the truck up from southern cali so maybe I should put some less viscous oil in it? It does get pretty hot here in the summer though.
TAKPAK
Hillsboro, OR
If it has been working right up to this point, I would check the connections in the wiring. On my M35A2, the gage started going crazy, and it wound up staying pegged at the high end. Had me spooked for quite a while. Finally, after much checking, I discovered that at the connection to the sending unit, even though it LOOKED like it was firmly in place, it apparently was not. Pulled it out, lubed it up a bit, then re-seated it "firmly" and from that point on, the gage worked perfectly, running right at "spec" pressures. Phew.....now I can sleep again.
