Tec tip of the day.
Floridianson
2,531
Interlachen Fl.
If your running a PTO watch for water build up in the front and rear rubber boots on the selector shaft. When deep fording be sure to drain the best you can and add appropriate lube to shaft as soon a possible.
Somemedic
Hobart, IN
Actually got my winch to work today. While I, gentlemen, may have read the manual on its proper operation it would seem that the clutch lever has not. Sometimes it engages and othertimes it just dont wanna move until you hand wind it and then the gears mesh. But it is cool to hear it working:twisted:
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
I put plenty of silicon grease inside the (OD Iron) boots and instead of letting the small end slide free on the shaft I install the end rim pressed between custom made stainless washers bolted to the end of the shaft, on both ends. At least that keeps them sealed against water/dirt for as long as the rubber lasts and stays flexible and it sure prevents the shaft from corrosion/pitting just where the oil seal should do its work: keep oil inside!
G.
m16ty
228
Dickson,TN
Your winch is working like it should. The clutch you're talking about isn't a clutch but a set of "dogs". Unless your drum stops just right you will have to turn the drum a little so the dogs will line up and go in. Don't do this under power because you are standing in a unsafe place and it's hard on the dogs.
