The Deuce....Yeahhhhh...It's home !! 1981 M35a2c
acesneights1
23
20
CT
Got my first Deuce...I love it. It is pretty clean. Little bit of rust here and there but the cab is spotless. It does not run. PO could not get it to start. He messed with teh fuel shut off. He said it was stuck bad. He got it to move but thinks he broke it. He said the truck started and ran high. He said it looked like a sleeve around it that cracked. He said he was not sure he put it back together right so I guess I will pull the cover off and see what's going on but he did say nothing fell in the pump...That is good...
61sleepercab
Walton, West Virginia
Good luck getting the big Tonka Toy started . On my M35a2, I have to use air on the fuel tank to prime her if she sits a while because the booster pump does not work yet. I have fun driving as my shins are longer than the space between the pedals and the steering wheel rim . Make you up a build/own picture book on paper or computer to preserve truck's history.
acesneights1
23
20
CT
Ok PO said the shutoff was stuck. Upon moving it back and forth he said the "sleeve cracked ??"
Nothing fell in the IP. He said he put it back together but it was racing when he started it and I should fix it before startin it . What is he talking about ? It is under the cover where the fuel shutoff lever is . I will take the cover off tonight.
whiskey357
Banned
168
chicago,ill
so the PO or IP or BS said what ??????????? have fun with it and welcome to the green madness.......When I got mine it didn't run so hot....Bad fuel and bad filters......all replaced then more fun and games ....so just took the baby to the fixer...mack truckplace...several weeks later good as gold for a few weeks...heheheheh that's just the start ......the green bug bite is for life...heheheh you can say I know that for something work...heheheh nice looking truck have fun..
cattlerepairman
3,473
NORTH (Canada)
If you already love your truck and you have not even heard it run, yet, just wait until you get to drive it! Your wife/gf will report you missing!
acesneights1
23
20
CT
I do love it already....lol
my will is being amended. I want to be buried in camo and no hearse...
my Deuce will take me to my grave..: )
sigo
Lieutenant Colonel
436
Leavenworth, KS
:shock: Well that must be some kind of record. It went from just arrived at home but not running, to ruined motor in less than 24 hours?
Sorry to hear about your truck. Hopefully it's not as bad as you think it is. What's the story?
