kapnklug
- 4
- 18
- spencer,ny
So I'm installing a flat plate style engine oil cooler on my 86 M1009, to bypass the leaky aluminum original lines and take some load off the cooling system. But now I'm wondering: is this something that should be run in series, like a transmission cooler? Also, I have an oil cooler thermostat (which did NOT come with the oil cooler, but could be made to fit with alot of screwing around). Should I bother using it, or can I run the oil lines from the engine directly to the new cooler? Any thoughts appreciated.
