Thoughts of future power plant 1009
Socal44
Calif.
I’m looking at delving into a trashed and sidelined CUCV. The motor is toast and has rats nested on the motor . What’s a common swap or replacement if you want to consider something other than the OE 6.2L? I’ve wrenched in the past on another platform maybe at the intermediate level, prob gonna be in way over my head but what the hell, I’m up for the challenge .
87cr250r
2,057
Rodeo, Ca
The 6.5 engines are still available and are a direct bolt in.
Any Chevy V8 will nearly bolt in. See if you can find one with an accessory rack that supports dual alternators.
Socal44
Calif.
Ah yes , that’s an operative question I should have included. As a general solution I’d prob pick a middle of the road build, not high end but not the cheapest way to get it running . Is it sacrilege to go gas?
Socal44
Calif.
I’m leaning towards an LQ9 or LQ4 , I know it’s cliche now but for a noob like me that seems like the most straightforward swap with lots of material to reference for trouble shooting
87cr250r
2,057
Rodeo, Ca
If you go the gas route you're going to have to do a lot of rewiring in order to convert the truck to 12V, unless you can find the dual alternator brackets. Check ambulances.
nyoffroad
718
Rochester NY
I've never changed one over but I don't see it being hard, One alternator and two batteries hooked in series and a few other things. Use the pink wire to the IP and move it to the distributor. Other that changing the starter I think even those wires can stay. Do away with the GP wires and I think you're pretty much done.
5,073
I am not up to all the legalities in CA. But would you have any concerns with emissions or any rules based on the vehicle changing fuels in CA? (I'm not trying to start anything, I just know CA is a lot more strict on these laws)
87cr250r
2,057
Rodeo, Ca
You can't charge the batteries in series because the 12 volt loads will kill the front battery. You can run a 24v to 12v converter to run your 12 volt loads if you want to run a single 24v alternator.
Emissions in CA are not a problem. There is no enforcement action on diesel trucks prior to 1997.
ehuppert
142
Upstate NY
Over the years I've had two diesel Chevys I repowered to 1st gen SBC's. Had the c30 dually for over 20 years. The M1008 I've probably had for 15 years. They weren't/aren't daily drivers, but got pretty regular use. I personally never cared about 24 volt systems or having dual alternators. These were work trucks for homeowner use! (firewood, plowing, material pu, etc)
As for wiring, not a show stopper. Pink Fuel solenoid wire becomes the Distributor power wire (at least for HEI/carb set-up) My C30 was a civvy version (obviously) so had less wiring concerns. My 1008 was a frame off restoration, so removed/modified wiring as needed for my use. Not hacked, but stripped down, cleaned up and re-loomed as needed. Bus bar now 12 volts, so makes a nice un-switched power distribution point!
Carb'd motor will be the easiest, but of course fuel injected provides better drivability.... Later generations SB's do provide more power potential, motor in my 08 is probably around 300 hp, so plenty for a work truck. (Mild cam, headers, carb/alum intake)
Both vehicles I retained the larger diesel radiator. Used appropriate sized exhaust adapters to join radiator hoses. Used the diesel trans convertor which was a non-issue!
Bottom line: It's not difficult and in my opinion is a upgrade. And, a carbed motor has very little troubleshooting required.... Fuel, spark, compression....
Once again, I drove these cucvs when they were new, allot! Hence, I have no love or allegiance for the 6.2!
