tire size for m1028 w/ duel wheels
hotroddiesel
stamps , arkansas
hey , i am the new proud owner of a 1987 m 1028a3 w/ the duel wheels and im trying to figure out how big of a tire i can put on my truck it has 16" rims and has stock supension if anyone can help me out i owe ya one .
Lawrence of Arabia
Howell MI
With spacers I'm sure you can go big. I have a 3" spacer on my 2007 and I have 285/R16s. My neighbor has 6" spacers, which I think is crazy, but he has huge tires. I'm sure some will tell you spacers are unsafe, but I have had them on several vehicles and had no problems. Can't stand empty wheel wells.
11Echo
96
CT W. R.
Most GM civilian dually pickups after 1981 were fitted with 235/85-16 tires. You can run 255/85-16's too. In the 70's I ran 750-16 and L78-16 on my duallies. No spacers necessary.
A pic of my 88 V30 with 235/85-16 and my 1008 with 255/85's, and my 79 with L78-16's.
GM72K10
68
Bucks County, Pa.
STOCK tires on 73-87 duallys were 7:50X16s or LT215/85R16s. LT225/85R16s also. LT235/85R16s came on SRW 1 tons. My 83 K30 dually has the old stock 7:50x16s only because they came with the truck and they're in good shape. If you plan on hauling a lot of weight with wider tires and no spacers you risk the tires rubbing, picking up rocks in between, etc.
11Echo
96
CT W. R.
Stock tires on 73-81 duallies were non-radial tubeless tires on 16.5 rims. I used to order the optional 7.50-16 D tube type on my trucks. GM went to radials in 82 on these models. My radial equipped duallies came with the optional 235/85-16 E tires.
hotroddiesel
stamps , arkansas
Thanks for all the info guys it helps a lot , does anyone know if I can fit 265 /75 on there with spacers in the rear ? It wouild be nice cuz I gt a whole bunch of this size layin around ?
