Transfer case drain plug
fpchief
225
South Alabama
My r-case drain plug is rounded out. Anyone have any suggestions? I have tried putting a flathead in beside the ratchet to tighten it up but not having any luck.
simp5782
Feo, Fuerte y Formal
9,493
Mason, TN
Buy a large bolt that will fit in it shorter the better. Take your welder and weld the bolt into it. Or weld a 1/2" extension into it or Whatever fits it
It is a typical pipe plug fitting if I remember right so a replacement is easy to locate
The weld will also loose the threads up as well on the plug for removal
