Transfer Case Leak Help!
Westex
El Paso, TX
M235 Deuce leak at the transfer case. It seems to be coming from the speedometer output shaft. Is this possible? Pictures below.
Westex
El Paso, TX
I just can't get the pics uploaded....this is the greatest site in the world, but when it comes to uploading pics from a digital camera, it just seems impossible. Pics are on my hard drive; I browse; select picture, then click upload and nada.......Any moderator help with the steps for a retard.....
wsucougarx
Washington State
It is highly possible...mine is leaking also. I parked my duece at church, came out 2 hours later...boom, noticed the deuce marked it's spot. Sorry church for leaving that 8 inch diamter puddle of GL-1:roll:
velociT
Burnet co. Texas
go to imageshack.us
-browse and upload the photo
-copy the direct link on the right
put
Westex
El Paso, TX
O.K., I'm sorry for all the drama, but there are the pics; my big ugly finger points to the speedo drive gear, which my mechanic swears the oil is pouring from. But I notice it is a greasable joint for the speedo shaft. When I drove it across most of America last weekend to get home, it was leaking GL-1 all over. Question is can you seal up the speedometer output device? Or do I have to buy another one and where?
G-Force
allendale nj
I do beleive there is an o-ring or seal in the speedometer drive. Take it apart and see. You can't make it any worse. Also check your vent on the caes to make sure it isn't clogged.
Westech
CPL
6,104
211
cow farts, Wisconsin
This is the same problem I am having. There is a seal that seals the oil from getting past the drive flipper. Where can you find one of the seals or the Tm that shows that part?
