Transfer Case Locked Up
Junglemist
Belize, Central America
The other day I was accelerating up a hill in third gear and as I shifted into 4th the 2 rear axles stopped turning. The truck would move forward or backwards a few feet, but something internally jams and it stops. I put the transmission and transfer case in neutral and the engine runs fine. With the transmission in gear the engine and transmission seems to run fine also, but if I put the transfer case in gear it locks up.
I got a friend with a truck to come tow me. The truck would not roll more than a few feet in either direction before stopping. That was even with the transfer case in neutral. I pulled the axle shafts and towed it off the road to a safe area. I then pulled the long rear drive shaft from the transfer case. With the axle shafts in and the drive shaft removed the truck rolls freely.
The transfer case appears to shift correctly since when it is in neutral the transmission spins freely.
So it seems that somewhere on the output side of the transfer case something is locked up.
The truck is an M35A2 with the air-shift transfer case.
Anybody have an idea what happened?:confused:
Divemaster920
Banned
494
VA
First, I would look on the outside around the emergency brake drum and see if anything has wrapped around it.
If that is all clear, there is something broke inside.
Junglemist
Everything is clear around the emergency brake drum. I figure something is broken internally, but I don't know what. I thought someone might have had a similar issue and have a good idea of what is broken.
The big question is should I tear it apart and try to replace an individual piece or do I need to get another transfer case?
Junglemist
The transfer case powers both the front and rear wheels. Pressurized air is run to the air cylinder on the front output of the transfer case to engage/disengage the front drive shaft. I have the front-wheel drive lever in the "out" position so the front drive shaft spins freely. The rear axles are always powered.
The problem is that power from the transmission enters the transfer case and somewhere in the output (Past the control lever) something is not turning.
I have searched the posts on here, but have not seen one with this issue. The transfer case never slips out of gear like they do when the gears are worn, and it has not been giving any odd noises.:?:
stampy
22
Henderson. NC
I thought air shift engaged only the front axle. If you pulled the rear driveshaft could you limp home with the front pulling? I had to do this on a jeep and a blazer when I lost the rear drive shaft. I just put the yoke back in and took it slow.
southdave
ripley, oh/TDY Lordstown,Oh
sounds like you stuck between high and low range, at least that was the case when it happen to me. after a breif panic and looking like wizard of oz pulling lever and such , I put in low range flip it in the front put it in reseve half throdel in pop back in and away I went. has not happen since. Maybe I got lucky but it worked mine was doing the same move 2ft each direction and lock up. by the way hows the amish down your way?
tm america
25
merrillville in
air shift is just for the front.i would look into the brakes both the e brake and the service brakes if a return spring breaks it can cause the brakes to lock up..i would check that first .
tm america
25
merrillville in
pull the drain plug on the t case just to get a little fluid out so you can check to see if there is alot of metal in the fluid. if so theres a good chance the t case is pooping out on you but i would look at the brakes first since that seems to be way more common
Junglemist
The brakes are fine. I towed the truck for about 8 miles with the drive shaft removed and the 2 rear axles roll freely. I checked the emergency brake and it is clear.
I did not attempt to use the front axle for the same reason that Mudguppy gave.
Divemaster920
Banned
494
VA
At this point I would just pull and take apart. They are not hard to take out. Make it easy to move if you set it on a 4 wheel appliance cart.
Junglemist
I have not tried anything like that. I was afraid of really breaking something, but I guess if the transfer case is a total loss then it might not hurt. I am going to try to check for metal pieces in the fluid.
Down here the people call themselves Mennonite not Amish. They are all over the country in different communities. Some communities still use horse and buggy while Mennonites in other communities have started many of the countries biggest businesses.
