Transmission and Transfercase oil
bcowanwheels
KINGSPORT, TN.
Nate, use pure synthetic straight 50 weight in the trans same as semi trucks use ans 85w140 pure synthetic in the t-case. Been usseing this for 25 yrs 0 problems. Also its a lifetime oil change,once in you,ll never have to change it again unless you get water in the boxes. I use castrol syn-gear lube.
Bob
