Transmission Oil - 80w/90 vs SAE 40/50
ctappan94
Jersey Shore
I know there's just about 10 million threads on it, but I've gone through them all & they ALL show different answers...
I'm looking for a smoother shift & an oil that will perform to the best capability.
I heard that SAE40/50 doesn't have extreme pressure additives, while someone else said Spicer stated these trans's shouldnt use extreme pressure additives...
Someone said the army only used 80w/90 to cut costs...
Just gimme the best option ! :)
shenkmen
12
Lancaster, PA
At the risk of starting another war...
Non-detergent 30, 40 or 50 wt was originally spec's by Spicer for the 3053a. I'm running it in my deuce and it shifts easier.
There's lots to read on this subject here.
MyothersanM1
19K M1 Armor Crewman
433
68
Culver City, CA
It's not a Deuce, but I put Rotella T1 50W in the 5-ton. It's much smoother than the the 80W-90 and is Spicer/Dana recommended. 2cents
jnbullock
Riverview, fl
New member and a new owner of a m932a2. Just drove her back to Tampa from Atlanta without any problems. I read the manuals for the transmission and was surprised that this one had transmission fluid instead of oil. It came with extra cans of train fluid. I changed out the filter and the fluid looks new. Any thoughts on why?
ctappan94
Jersey Shore
Transmission fluid like SAE 50 but synthetic?
Hey All,
SAE 50 is hard to find & I prefer it used in my transmission. However.... Is there a synthetic or conventional fluid that is similar to SAE 50, excluding GL 5 80w/90 MT1. I dont want to use that. Can I use a 5w 50 or 10w50, etc etc.
thanks@
1,187
Why don't you want to use the correct oil?
You do not want to use synthetic. Issues have been reported.
If you want to deviate from the norm, you'd better do your homework(or you'll pay).
1,187
The military used GL-1. Not 50W.
If you want to use 50Weight, you need to use straight 50 w, not a milti viscosity.
One has degergent and one does not.
Why not use GL-1, or GL-5?
1,187
It worked fine for the last 60 years.
1,187
If you can't find 50w local, then you can order it online.
Why make it more difficult than it needs to be.
Karl kostman
917
Fargo ND
Use the same oil that has been used forever in these trucks, and make positive it GL-1 or GL-5 compliant, in other words YELLOW METAL FRIENDLY, Very important!
KK
shenkmen
12
Lancaster, PA
Automatic transmissions use a flavor of automatic transmission fluid. Don't you have an automatic in the 923?
