Transmission support mounts
Jbush
Pensacola, Fla
Replacing my exhaust I found that my transmission support mounts have been (lack of a better word) destroyed. Does of of the members know where I can find them or something else I can use.
bcowanwheels
KINGSPORT, TN.
James, there's 2 bolts that ARE 5/8'S NC bolts that holds the trans mount to the back of the transmission, there notorious for comming loose/backing off. Everyone i,ve worled on they have been loose ( + 35 trucks). You need to replace these bolts with studs, flat and lock washers (all grade #8 along with red lock tite. the one on the driver side will need to be shorter than the passenger side stud.
Bob
Jbush
Pensacola, Fla
Thank you got the problem fixed. I found the spacer and bushing for the passenger side at surplus jeep. the price was very reasonable.
