motormayhem
- 18
- 18
- Tucson, AZ
Ok well I just finished up my d44/14 bolt FF install in the m1009. The rear now has 4.1's instead of the 3.08 stuff and I can really tell the difference. I am running 36" tires, but the motor really seems to get going at 50 and I am a little hesitant to take it up to 65 for highway driving. Anyway my th400 got cooked running 3.08's and 35" tires so I am in the market for a transmission. I figure while I am going to have to spend $$ on a tranny I should get something with an overdrive. So far from what I have read the GM stuff is a 700r4 or a nv4500. I am fine with a manual and if it is not to much work would prefer not to have to worry about large tires and hot transmissions. How difficult is it going to be if I can find a 90's 6.5 turbo truck for a doner to fit the 4500 in the m1009? I am looking for something that is more or less a bolt in job where I dont need to get adapters and special mounts and such. Also can I run a np208 on the 4500 or will I need to get new driveshafts and such for a different t-case. As for the 700r4 that uses a lockup torque converted correct? If I use that will I be able to use a 208 and keep my driveshafts? Any info on what my options are and what I will be looking to buy would be great.
