treasure chest
gishane
washington
so cleaning out the 42 and found a bunch of goodies under the seat ,tire chains,u-joints,fuel pumps,hand crank for engine,and some kind of air brake/linelock devise.
fixed the exhaust leat and horn ,and took her to local car show WOWed them ,
think Ill commute to work monday .. look out I405.
paulfarber
20
Gordon, PA
OF COURSE!!! The engine crank to! Did it also have the bumper bracket? Those things need repro'd as there are none.
I would like to see the fuel pump as the AC type F fuel pump on the CCKW is unique. Even better if it was the 6 valve late war pump... those are hard to find in good shape. I'd pay $100 easy for a rebuildable CCKW fuel pump.
gishane
washington
well ok then
So now I know Ill take some pics tomorrow , the bracket is still on the bumper ,
and I hope the fuel pumps are the right ones because I got 3 or 4 of them ...
Ill keep you posted.
"where ever you go ,there you are"
paulfarber
20
Gordon, PA
If the crank bracket is welded on the easiest way to tell if its an original issued part is that the originals had two ears bent at 90 deg to keep it seated in the bumper holes. So if you can, look under the bumper for those ears.
It'll take a fuel pump if you can send me pics. I need all 4 sides and from the top. Price will depend on condition. There were some steel parts that can rust and make repair a pita.
