Trouble cross referencing glow plug relay
fireman5214
29
Nazareth, Pa
Hello All,
Our M1028 truck was recently inspected for the year at the fire company and the mechanic said the glow plug relay was bad. He said they are about 30.00 but told us we could install it ourselves to save on costs. He did not give any type of part number. I tried cross referencing the numbers but I am coming up short and can not find a replacement at Autozone, Advanced Auto Parts or Napa. Does anyone have the correct cross reference part? I kept looking it up last night but everything says does not fit your vehicle. I have highlighted the part I need from the technical manual.
Thanks in advance.
Guyfang
26,010
Burgkunstadt, Germany
14076885
7X677
1759100
45152
1759100
[75Q65
5950011928653
] A00AM
974-1215-010-09
[ 88136
98226
[ 88136
[I 98226
[ 72055
Alternate part numbers and suppliers number
45152OSHKOSH CORPORATION
72055CAMDEC CORP
75Q65OSHKOSH DEFENSE, LLC
7X677GENERAL MOTORS LLC
88136TROMBETTA CORPORATION
A00AME.C.A ETABLISSEMENT CENTRAL
Tech info
OVERALL LENGTH3.000 INCHES NOMINAL
CENTER TO CENTER DISTANCE BETWEEN MOUNTING FACILITIES PARALLEL TO LENGTH2.125 INCHES MINIMUM SINGLE MOUNTING FACILITY AND 2.250 INCHES MAXIMUM SINGLE MOUNTING FACILITY
OVERALL HEIGHT2.430 INCHES NOMINAL
OVERALL WIDTH1.830 INCHES NOMINAL
MOUNTING SLOT WIDTH0.250 INCHES NOMINAL SINGLE MOUNTING FACILITY
ENVIRONMENTAL PROTECTIONDUSTPROOF
FRAGILITY FACTORMODERATELY RUGGED
WINDING QUANTITY1
PURPOSE FOR WHICH DESIGNEDUSED WITH
COIL QUANTITY1
WINDING DC RESISTANCE RATING6.0 OHMS NOMINAL SINGLE WINDING
DUTY TYPEINTERMITTENT
ARC QUENCHING METHODAIR
MOUNTING FACILITY TYPE AND QUANTITY2 SLOTTED HOLE SINGLE MOUNTING FACILITY
STORAGE TYPEGENERAL PURPOSE WAREHOUSE
III CUBIC MEASURE13.341 CUBIC INCHES
MOUNTING FACILITY PATTERNIN-LINE SINGLE MOUNTING FACILITY
NONPILE-UP MAIN CONTACT ARRANGEMENT1 POLE, SINGLE THROW, NORMALLY OPEN, DOUBLE MAKE, MOMENTARY ACTION
OPERATING VOLTAGE RATING AND TYPE AT SPECIFIED TEMP12.0 VOLTS DC 25 DEG CELSIUS SINGLE WINDING
MAIN CONTACT LOAD CURRENT RATING AT MAXIMUM RATED VOLTAGE80.0 AMPERES DC RESISTIVE LOAD
MAIN CONTACT MAXIMUM VOLTAGE RATING IN VOLTS24.0 DC
TERMINAL TYPE AND QUANTITY4 THREADED STUD ALL FUNCTIONS
Maybe this helps.
fireman5214
29
Nazareth, Pa
Thank-you! Where did you find this information?
14076885 7X677
175910045152
1759100 [75Q65
5950011928653 ] A00AM
974-1215-010-09 [ 88136
98226 [ 88136
[I 98226 [ 72055
72055CAMDEC CORP
Tech info
WINDING QUANTITY1
COIL QUANTITY1
Maybe this helps.
1,187
I feel we'd be remiss if we did not mention in this thread that the correct relay has an isolated ground.
Not all relays are this way and they do look alike.
Test whatever you get before installing it. Use an ohm meter or continuity tester and be sure there is no continuity(connection) between the outside case(and mounting tabs) to either of the small lugs.
If you install the wrong relay, you could end up energizing your glow-plugs continuously and burn them out.
fireman5214
29
Nazareth, Pa
Thanks, Could this be why when I saw a guy putting one of these on a 1009 on youtube use a manual push button with a rounded relay?
fireman5214
29
Nazareth, Pa
The one that we saw on the truck tonight now that I had time to get the info is as follows ( I am assuming its the same as above by antennaclimber)
98226 12v/continuous
Torque Max
Camdec Corp. 04/01/1998
AU2199
fireman5214
29
Nazareth, Pa
Just an update, it was not the glow plug relay. We got our local AutoZone to donate AC Delco glow plugs for us and we changed them out, the truck starts fine. Thank-you to everyone for the help with this!
