Trouble starting Deuce
deconn
Hamden/Connecticut
Hears the story, Started the deuce moved it 30 ft. shut it down, went back to start it, wouldn't turn over just a clunk. I have replaced the starter and the relay, still a clunk. The amp meter in side the cab gets nailed when I push the starter button, so theirs a short somewhere. I have checked the wiring, its strange start one minute then this. Does anyone have any ideas? Thanks, deconn
simp5782
Feo, Fuerte y Formal
9,497
Mason, TN
How many volts do you have on the start signal wire at the starter when the button is pushed? If you think it is a short, easiest way to check is to run a new wire from the start button to the starter with alligator leads to see if that fixes your problem. just cut the insulation on the wire up by the start button to clip on.
Another temporary fix is to shake the harness in and around the dash or around the starter and see if it starts while you do it.
Floridianson
2,521
Interlachen Fl.
Was this a small clunk click or a truck shaking clunk bang like you might have hydro locked.
One mans clunk is another mans treasure.
SETOYOTA
451
georgia
The push button switch may be your problem. I have had the same problem with 2 trucks and it was the switch.
