Tuck this one away in the recesses of your brain: Modulator Cable Stretch...
StackJ
-2
SoCal
The end of a long journey. Bought an auction HMMWV stating it had a bad tranny and wouldn't shift into 3rd. I thought, ok, it's the modulator cable. I'll replace it. (After confirming with members here...).
Drained the fluid, it was black and smelly and had water in it. Decided to rebuild, did. (Rebuilt a second as well.)
Put the tranny back in. (Something I won't do again, I hope.) Replaced the modulator cable with a donor.
Shifted manually. Wouldn't go into 3rd except when we pulled the cable. Tightened all of the play out - till there was no more threads left. No worky.
Cut 3/4" off the cable, bought a 3/32 ferule and crimped it on.
Works like a charm!
StackJ
-2
SoCal
Thanks, that was not my issue. It was simply not shifting into 3rd when in drive. Have not checked kickdown yet. Just wanted to shift into 3rd normally as a start...
StackJ
-2
SoCal
Kickdown circuit tested fine and worked. Very glad this crazy-priced thing which amounts to a small normally open switch worked.
If the thing won't go into 3rd on its own, modulator first since the switch is normally open anyway. The modulator is 100% mechanical and the cable did its job if pulled manually.
