tune-up parts
blisters13
79
Beaumont in SoCal
Hi All:
Getting ready to get my first M35 with a 3 hour drive, so I was hoping some of you could please list basic items such as fuel filters and belt(s) I should take with me. I will need the part numbers and whether I can use NAPA or such.
THANKS very much!!
-Ken J
WillWagner
3,151
Monrovia, Ca.
BFS, Tire changing tools, a jack, jumper cables, a chase vehicle, air hose and fittings to connect to the truck and a tire filler. there is only one "special" hose, the lower rad. the rest are just stick hose in 2 inch 1 3/4. Napa #s for the lower are 20611 or 7759...this fits better. Alt belts, Napa 25-9470 for two, Compressor 25-9510. Have someone with mechanical knowledge go with you and look at all the fluids and such.
blisters13
79
Beaumont in SoCal
I know a BFH is a hammer, what's the "S"?
THANKS very much for the list; will go and get some stuff next paycheck.
Oil and especially fuel filter numbers??
I live in Beaumont, and I will be retrieving the truck in Santa Clarita (assuming my on-going financial plans work out). $500 down on the truck already.
I have sockets including 3/4" drive (with square socket for inner lug nuts) and wrenches up to about 1 3/4"; a nice 12 volt compressor for the chase truck.
Also, what kind of oil goes in the M35 compressor? Anything special for coolant? Is there power steering and what fluid does it take?
AGAIN, THANKS!!
hndrsonj
Senior Chief/Moderator
377
Cheyenne, WY
The first thing is to get into the manuals. You'll learn ALOT. BFS is DOT 5 brake fluid. There isn't power steering. Possibly have the air assist but doubtful.
Warthog
244
OKC, OK
Oil and especially fuel filter numbers??....................
AGAIN, THANKS!!
BFS - Brake Fluid Silicone i.e. DOT 5
If you are asking these questions then you really need to do some research on what it takes to maintain/operate a Deuce. Please do this before you even get behind the wheel. There are lives at stake when you drive a 13,000 lb vehicle.
First off the compressor doesn't take any oil. It is feed thru the engine. And most Deuces do not have power steering and the ones that do are air assist.
Read the following threads
Deuce - Steel Soldiers::Military Vehicles Supersite
http://www.steelsoldiers.com/deuce/...litmate-deuce-recovery-list-instructions.html
blisters13
79
Beaumont in SoCal
Warthog:
I understand your concern- I have lived with the dangerous traffic of southern California all my 42 years and recently seen a LARGE number of stoopid things on the I-10. But you have taken my lack of experience with a certain model of truck and translated it into an inability to safely drive a truck which only weighs 6 1/2 tons.
I earned a Class A license (semi trucks rated to 80,000 pounds) when I was 20 years old. While I don't drive one often, I have done it many times. I have also operated heavy equipment since I was a teenager and have a current mobile crane operator's certificate (state-recognized).
I understand reading manuals is a great place to start and it would be nice to even make it mandatory, but the Operator's Manual is just under 400 pages. With two kids, a job, and all the family things which suck up time, I will not be able to review the manual before it's time to get the truck. And that's not even counting the Organizational Repair manual, let alone the Depot repair manual. So I AM doing the research; asking questions here is about the same as going to someone's house and asking them there, except that I don't have to find the time to do it on their schedule and I get the advantage of several opinions and experiences instead of one. Also, graveyard shift generally precludes me from interacting with other people on a normal schedule.
The link to the "...Deuce Recovery List..." was excellent! Thanks very much for that. It didn't show up when I did a Search or when I posted this thread. I have printed it out and will start buying parts and fluids.
Thanks very much for your answers and it's good to point out to newbies that these things are not like pickup trucks, not even the bobbed ones.
I like Chevron DELO. Does anyone have any reason to NOT use this brand and type of oil?
jollyroger
Centennial, Colorado
Delo or Shell Rotella T 15W40 for motor oil.
To check the brake fluid there is a hinged plate on the drivers side floor. Flip it up and there is a vent line in the top of the plug in the top of the master cylinder. You have to remove the vent line before you can remove the plug so you can check the brake fluid level.
Since you have driven a Semi you know about the glad hands. Buy a glad hand air filler hose or a gladhand and a regular compressor air hose and the air hose quick connects. I prefer the ones with a quick connect at the end so I can put other tools on it besides a tire filler. Sometimes you want to run a drill or an impact wrench. Most of the time I use the hose with a blow gun attachment to fill my air mattress or entertain my dog with the compressed air.
blisters13
79
Beaumont in SoCal
Will Wagner- Sorry, I guess I coulda made my reply iin a separate post. I mentioned in post #4 above that I'm in Beaumont CA.
jollyroger- cool thanks, I have added a gladhand with threaded hub for a quick-connect to my list. I have hoses for around the garage, so I'll be taking them with me.
I might have talked one of the mechanics here at work to go with me. He was a deuce recovery driver/mechanic in Viet Nam. His company was equipped with 5-tonners, though. He had one of the awesome recovery trucks with boom and etc. One time he had FIVE trucks cabled together like a train to get them all back to the base. I think he'll be an excellent man to bring along.
THANKS TO EVERYONE for the advice and info!
jollyroger
Yes. Bring that guy for sure. Buy him a steak dinner after you and he get back safely.
After you get this truck......And then your 5 ton, tee hee, you will need a towbar so if one truck goes down you can recover it with the other.
There is no cure for the OD fever.
WillWagner
3,151
Monrovia, Ca.
Sorry, I didn't see that. You should think about coming out to the dez event next month.
blisters13
79
Beaumont in SoCal
Yeah, that's the one you called me about. Can't go- daughter's b-day with family from around So Cal.:beer:
THANKS for the invite! I will make it to something (when's the next trip to the Fontana parts depot, er, junkyard?).
