Turbo oil drain back gasket
shootiniron
13
Escalante,Utah
Has anyone here replaced that gasket in-place? Is it a real pain and also can I use a gasket sealant with it? I've got two different types of gaskets.One is a standard paper type,the other is a hardened kind of gasket. Which would be better? Thanks!
WillWagner
3,161
Monrovia, Ca.
If you are there, do the drain line too. It will be easier to take the whole drain line off so you can clean the old gasket off of the turbo and drain line flange. Not a big job.
