Turn signals only work once truck is warm
Dylandeuceman95
Laporte Indiana
Hello everyone, little stumped here. Since I got my truck about a month ago it seems the turn signals only start to work and blink once the truck has ran for about 15 mins. If I flip them on when trucks cold the indicator blinker light will come on solid and the outside lights will not blink until truck is warm, then both indicator and turn signals will blink as supposed to. I put a new switch in it and still the same thing. All other lights work whenever commanded to do so. It’s only the turns that are being weird. Any tips or thoughts are appreciated. Thankyou!
Barrman
2,218
Giddings, Texas
One of my trucks does the same thing, sometimes. I am convinced it is my blinker box/relay. Here is a video about how to test the flasher box:
I live down a dirt road and have learned with that truck to just turn the blinker on when I start the engine. If it works, then it will probably work the rest of the drive. If it doesn’t flash, I just leave the blinker arm full left or right while I idle toward pavement. It will normally start blinking like it should before the end of the dirt.
HDN
5,558
Finger Lakes Region, NY
@Dylandeuceman95 have you noticed if the outside weather or air temperature affects how long it takes to start working? I was wondering if there were mechanical contacts that are worn out and only work if they've expanded a little bit due to engine compartment heat.
Dumb answer: Maybe the blinker fluid hasn't been changed? Have you had oil analysis run on it? :p (Sorry I felt this was a good time to bring it up.)
Dylandeuceman95
Laporte Indiana
lol yea I’m thinking it’s definitely related to a contact of some sort expanding and making contact once it’s warms up the connections a bit, but if not in the switch, what else is there?
Dylandeuceman95
Laporte Indiana
Maybe it’s in the lighting switch itself. Upon further review of the diagram it looks like it has wires running through the main light switch. May have just answered my own question…. I’ll pry replace the main switch and report back with my findings.
HDN
5,558
I believe there's a flasher unit in the engine compartment somewhere. I don't know the location offhand as I've never had a reason to look for it. I'm pretty sure the old ones are mechanical. There are newer solid state ones, but it seems the newer replacement ones have longevity problems.
cattlerepairman
3,525
NORTH (Canada)
I had the same issue (several times, with several "new" flasher boxes). The flasher box usually sits inside the driver side fender. What is being sold as "replacements" - in my personal opinion - are already defective units, stuff that has not passed QC for the contracts but gets sold on the open market anyway etc. The electronic board is completely puttied and it is futile to try and fix it.
My recommendation is to build a flasher box (super easy to do), using an easily replaceable civy 24V flasher relay housed in a sturdy plastic box. Enough room to toss a spare relay into the box as well, just in case. Beats forking over 60 bucks every time the stupid thing dies.
