Used motor oil in a detriot 2 stroke?
davesgmc
131
Mclouth, KS
What are anyones thoughts about using waste oil in a 6-71 detroit? I have several hundred gallons of the stuff that I can use. I was goping to filter some, and cut it 50/50 with diesel. Not sure that the motor not being a multi fuel and also being a 2 stroke how it would work. What do ya'll think?
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
I was thinking of adding some used motor oil to a old diesel tractor I have. Not a two stroke, just a regular diesel. I would try it if it was my truck, not sure I would recommend for someone else to try it.
1958 M274
North GA
I’ve used a little in my Gama Goat (with a 3-53). It’ll run fine, if you can get it started… Keep the ratio low. I wouldn’t go more than 5% in the summer, and very little or none in the winter.
Jones
Sacramento, California
50/50 might be a little thick. Might start off around 10% and see what results you get. 2-stroke doesn't matter as it's still a diesel but with no FDC you'll have to stay within what will flow through the fuel system.
DEFINATELY filter first; water and/or abrasive contaminants will make short work of those Detroit injectors.
davesgmc
131
Mclouth, KS
well, maybe i will just stick with straight diesel, hate to have 50 gallons of ruined oily diesel crap sitting around i cant do a thing with
Bill W
47
Brooks,Ga
I once cleaned the fuel tanks on a Motoryacht with a pair 8-71's the the owner of this boat was blending UMO at 25 to 1., He said this was approved by Detroit diesel, I'm sure this was modest ratio by the factory
beaubeau
Salisbury,N.H. 03268
A little won't hurt. I used WMO in my 3406B cat on a regular basis and it actually went further on a tank. I run some in my 6-71Detroit with no problems. 5-10 gallons to a tankful is safe!! Think obout all the Countries that do not have STRICT EPA laws, like Mexico, do u think their fuel is Clean like in this country.?? Good luck, Phil
