used WVO.....I think
rizzo
Port Huron, MI
I've gotten some oil or maybe grease from some places here in town. I don't think it will work cause it is like crisco at room temp. Am I right?
cranetruck
92
Meadows of Dan, Virginia
If you want to use 100% WVO, it must be heated to about 160°F by the time it hits the IP.
If you want to blend it with diesel, it should be like a cooking oil at room temp.
In your case, it can always be converted to biodiesel by processing with methanol and lye.
reblawyer
Tupelo, ms
I've been running some mixed with diesel and had great success. I do filter through denim, a pain, but it makes me feel secure in the purity.
reblawyer
Tupelo, ms
Meant to say "running some wvo from the local chinese place". Its pretty viscous so I have to heat to at least 120 to filter but its great adding 20% of it to my diesel, cuts down on the heavy exhaust fumes too.
rizzo
Port Huron, MI
Re: RE: used WVO.....I think
grease or oil?
reblawyer
Tupelo, ms
RE: Re: RE: used WVO.....I think
Rizzo, Sorry for taking so long to reply, been out and about. It is actually oil, the kind they use for wontons and egg rolls and the like.
rizzo
Port Huron, MI
I found out that the Mexican place is using oil, but they had some grease mixed in because someone ordered the wrong stuff.
I added 5 gal of filtered WVO to my 1008 yesterday and it rand great all day. Started hard this morning. I filled up on diesel and found out that I had a 50 -50 mixture. I think I also had some of the grease mixed in too. I am doing some organizing and get things straightened around so that I only use the oil. I am going to start making bio soon.
reblawyer
Tupelo, ms
Once your'e into the bio you will probably good to go in all conditions. I'm going to stick with using the oil, right now and doing a little engineering on my whole heated tank system, from free or cheap parts.
CCATLETT1984
Saint Clair Shores, MI
Re: RE: Re: RE: used WVO.....I think
I have my setup almost done, just need to make the time to finish wiring the pump and secure a few fittings. then it's off to get some oil and lye.
rizzo
Port Huron, MI
lets compare notes. I'm going to start looking for the ingrediants next week after my bog on the 11th. I will PM you with what I found, how much and where.
